Ivan2022
Nov 07, 2021Guide
CAX80 Blocking Access to RealVNC
CAX80 Port/Firewall Issues w/ RealVNC I was gifted a Netgear CAX80 and have it setup and working, as best I can tell with everything I need, except RealVNC. RealVNC says it can’t connect to the ...
Nov 08, 2021Guru - Experienced User
Are you using IPv6?
Have you tried a different DNS provider?
Have you contacted RealVNC?
from their site, they look fairly responsive to support questions.
- Ivan2022Nov 08, 2021GuideYes I am using ipv6. I have tried several DNS providers as well. I haven’t heard back from RealVNC support yet, which was why I’d also posted here hoping someone may have a solution.
- plemansNov 08, 2021Guru - Experienced User
Is upnp enabled?
have you tried disabling it and redoing the port forwarding?
https://help.realvnc.com/hc/en-us/articles/360002249797#establishing-a-direct-connection-0-0
- Ivan2022Nov 08, 2021GuideYes I tried disabling upnp with the forwards active and still no success, reboots after each change for good measure as well.
