Ivan2022
Nov 07, 2021Guide
CAX80 Blocking Access to RealVNC
CAX80 Port/Firewall Issues w/ RealVNC I was gifted a Netgear CAX80 and have it setup and working, as best I can tell with everything I need, except RealVNC. RealVNC says it can’t connect to the ...
Ivan2022
Nov 08, 2021Guide
Yes I am using ipv6. I have tried several DNS providers as well. I haven’t heard back from RealVNC support yet, which was why I’d also posted here hoping someone may have a solution.
Nov 08, 2021Guru - Experienced User
Is upnp enabled?
have you tried disabling it and redoing the port forwarding?
https://help.realvnc.com/hc/en-us/articles/360002249797#establishing-a-direct-connection-0-0
- Ivan2022Nov 08, 2021GuideYes I tried disabling upnp with the forwards active and still no success, reboots after each change for good measure as well.
- plemansNov 08, 2021Guru - Experienced User
Is it only 1 computer that has the realvnc on it? If so, you could put its ip address into the netgears dmz.
It's on my Windows PC and MacBook (VNC Server), but the only one I care about is the Windows one. I'll give the suggestion you made a shot this evening when I'm back home.
Thanks!
