BillyHSat
Jun 15, 2022Guide
CAX80 Bricked Only Power LED on
Howdy all. I have a bricked CAX80 that has only the power LED light on. Resets don’t work and unable to access the unit at all to attempt a firmware load. Suspect hardware issue. Netgear won’t allow m...
BillyHSat
Jun 16, 2022Guide
Correct. Also tried powering off then holding reset button while powering on to no avail. Totally unresponsive. After power is supplied, front panel ethernet ports 1-4 will initially light up, then darken, and then only the power light will be on white and steady. This might be the worst hardware component as far as reliability and troubleshooting (and company support) I've ever come across.
Jun 16, 2022Guru - Experienced User
Send those two moderators a private message and see what your options are.
