SD92113
Jul 25, 2022Initiate
CAX80 bricked power light on/ no response to ping
Same thing as everyone else. Nothing works! The modem router powers on and that’s about it. Can’t do a rest, hard reset or connect via tftp mode because it won’t even go into that mode. When CAX80 is ...
michaelkenward
Jul 25, 2022Guru - Experienced User
SD92113 wrote:
Same thing as everyone else. Nothing works! The modem router powers on and that’s about it. Can’t do a rest, hard reset or connect via tftp mode because it won’t even go into that mode. When CAX80 is connected to my laptop, I run ipconfig and see that my laptop sees the Ethernet connection but CAX80 won’t response to pings (100% loss).
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
I will ask the Netgear moderator to move your message.
