SD92113
Jul 24, 2022Initiate
CAX80 bricked power light on/ no response to ping
Same thing as everyone else. Nothing works! The modem router powers on and that’s about it. Can’t do a rest, hard reset or connect via tftp mode because it won’t even go into that mode. When CAX80 is ...
Jul 25, 2022Guru - Experienced User
What are the front LEDs showing?
So you can't access 192.168.1.1 or 192.168.100.1 after you press the reset button for 10 seconds then release?
- SD92113Jul 26, 2022InitiateFront led that is lit up is the power one. Bright white no flash. And no I can’t access the default IP address of the CAX80.
Trust me I have read a lot of the post on here about the CAX80 situation that I am experiencing and obviously NG does not care to share on how to fix this hardware issue. This is not a user issue, this is a device issue.- FURRYe38Jul 26, 2022Guru - Experienced User
You'll need to contact the forum moderators listed in that link I posted and ask for additional help and information regarding this. This is beyond forum help.
