SD92113
Jul 24, 2022Initiate
CAX80 bricked power light on/ no response to ping
Same thing as everyone else. Nothing works! The modem router powers on and that’s about it. Can’t do a rest, hard reset or connect via tftp mode because it won’t even go into that mode. When CAX80 is ...
Jul 25, 2022Guru - Experienced User
What are the front LEDs showing?
So you can't access 192.168.1.1 or 192.168.100.1 after you press the reset button for 10 seconds then release?
SD92113
Jul 26, 2022Initiate
Front led that is lit up is the power one. Bright white no flash. And no I can’t access the default IP address of the CAX80.
Trust me I have read a lot of the post on here about the CAX80 situation that I am experiencing and obviously NG does not care to share on how to fix this hardware issue. This is not a user issue, this is a device issue.
- FURRYe38Jul 26, 2022Guru - Experienced User
You'll need to contact the forum moderators listed in that link I posted and ask for additional help and information regarding this. This is beyond forum help.
