Kenwilson0619
Aug 16, 2023Aspirant
Cax80 cable modem and nest wifi router and 2 access points
Hi everyone! I’ve been looking into how home networks should be optimized and I had an idea to reconfigure my current setup to be more optimized for speed. I’ve been trying to level up my home network...
Aug 16, 2023Guru - Experienced User
When in modem mode, access the CAX80s web page at 192.168.100.1
- Kenwilson0619Aug 16, 2023AspirantIf you forgot the password, can you recover it or reset it?
- FURRYe38Aug 16, 2023Guru - Experienced User
Try entering the PW wrong 3 times, does it give you a recovery. If not, then you'll need to factory reset the CAX80 and setup from scratch. Then log in to routerlogin.com or 192.168.1.1 using a wired PC and web browser and walk thru the setup wizard. Be sure write down all important information for safe keeping later on.
