AlexanderSextus
Nov 04, 2021Star
CAX80 can't upload 5GHZ
Im having serious issues trying to get this figured out, ive tried playing with everything for teh last 6 hours to get my uploads to work in 5ghz mode. Im literally 25 feet from the router and any fi...
- Jun 14, 2023
Firmware version 5.1.1.2 is what everyone needs to push for to be released.
My_Username
Nov 04, 2021Apprentice
2.1.3.5 just became available for the CAX80. I just updated and it got me this far. I don't know if it will be helpful for your issue as 5GHz always worked for me.
Something to try though...
- AlexanderSextusNov 04, 2021Star
Strange, i dont see that update?
Also, i bought a NEW CAX80, set it up and am habing the same issue..... on a NEW DEVICE.
SPENT 2 hours with Netgear support to no avail... in anycase maybe theres something wrong here in my cable connection?
Everything else on this router is bone STOCK, as in out of teh box fresh.
- My_UsernameNov 04, 2021Apprentice
I didn't find it on Netgears support page.
I opened the routers setup web page, then Advanced/Administration/Router Update. I pressed the "Check" button, the router phoned home and found the update.
- plemansNov 04, 2021Guru - Experienced User
A lot of times the auto update server gets the update first and then it goes to the support site.
- FURRYe38Nov 04, 2021Guru - Experienced User
Let see if we can get these pictures approved...
