AlexanderSextus
Nov 03, 2021Star
CAX80 can't upload 5GHZ
Im having serious issues trying to get this figured out, ive tried playing with everything for teh last 6 hours to get my uploads to work in 5ghz mode. Im literally 25 feet from the router and any fi...
- Jun 14, 2023
Firmware version 5.1.1.2 is what everyone needs to push for to be released.
Nov 04, 2021Guru - Experienced User
A lot of times the auto update server gets the update first and then it goes to the support site.
AlexanderSextus
Nov 04, 2021Star
Just updated and no luck. STILL have issues uploading to websites like Wetransfer.
However now dropbox is cool to upload to? now im super confused.
help.
- FURRYe38Nov 04, 2021Guru - Experienced User
Did you factory reset the modem and setup from scratch after you updated?
help.
- plemansNov 04, 2021Guru - Experienced User
Have you tried a different DNS provider?
- AlexanderSextusNov 04, 2021Star
Cable Diagnostic Status: Good Action: Your setup looks fine. If you are still experience an internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info. Internet Access: Downstream Status: Upstream Status: Refresh Save Cable Diagnostic Info Advanced Information Frequency Start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure Procedure Status Comment Acquire Downstream Channel 645 MHz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked 256 QAM 36 645000000 Hz 4.7 dBmV 45.5 dB 0 0 2 Locked 256 QAM 9 471000000 Hz 4.0 dBmV 45.9 dB 0 0 3 Locked 256 QAM 10 477000000 Hz 4.0 dBmV 45.7 dB 0 0 4 Locked 256 QAM 11 483000000 Hz 4.1 dBmV 45.8 dB 0 0 5 Locked 256 QAM 12 489000000 Hz 4.2 dBmV 45.7 dB 0 0 6 Locked 256 QAM 13 495000000 Hz 3.9 dBmV 45.5 dB 0 0 7 Locked 256 QAM 14 507000000 Hz 4.3 dBmV 45.8 dB 0 0 8 Locked 256 QAM 15 513000000 Hz 4.0 dBmV 44.6 dB 0 0 9 Locked 256 QAM 16 519000000 Hz 4.0 dBmV 38.2 dB 0 0 10 Locked 256 QAM 17 525000000 Hz 4.3 dBmV 42.2 dB 0 0 11 Locked 256 QAM 18 531000000 Hz 4.0 dBmV 43.0 dB 0 0 12 Locked 256 QAM 19 537000000 Hz 4.4 dBmV 44.4 dB 0 0 13 Locked 256 QAM 20 543000000 Hz 4.3 dBmV 45.4 dB 0 0 14 Locked 256 QAM 21 555000000 Hz 4.3 dBmV 42.1 dB 0 0 15 Locked 256 QAM 22 561000000 Hz 4.6 dBmV 36.4 dB 0 0 16 Locked 256 QAM 23 567000000 Hz 4.3 dBmV 41.0 dB 0 0 17 Locked 256 QAM 24 573000000 Hz 4.4 dBmV 39.3 dB 0 0 18 Locked 256 QAM 25 579000000 Hz 4.4 dBmV 43.1 dB 0 0 19 Locked 256 QAM 26 585000000 Hz 4.9 dBmV 45.7 dB 0 0 20 Locked 256 QAM 27 591000000 Hz 5.0 dBmV 45.8 dB 0 0 21 Locked 256 QAM 28 597000000 Hz 5.2 dBmV 45.9 dB 0 0 22 Locked 256 QAM 29 603000000 Hz 4.9 dBmV 45.8 dB 0 0 23 Locked 256 QAM 30 609000000 Hz 5.3 dBmV 45.9 dB 0 0 24 Locked 256 QAM 31 615000000 Hz 5.1 dBmV 45.8 dB 0 0 25 Locked 256 QAM 32 621000000 Hz 5.1 dBmV 45.6 dB 0 0 26 Locked 256 QAM 33 627000000 Hz 5.2 dBmV 45.1 dB 0 0 27 Locked 256 QAM 34 633000000 Hz 5.0 dBmV 44.8 dB 0 0 28 Locked 256 QAM 35 639000000 Hz 4.8 dBmV 45.2 dB 0 0 29 Locked 256 QAM 37 651000000 Hz 4.5 dBmV 45.3 dB 0 0 30 Locked 256 QAM 38 657000000 Hz 4.3 dBmV 45.2 dB 0 0 31 Locked 256 QAM 39 663000000 Hz 4.4 dBmV 45.2 dB 0 0 32 Locked 256 QAM 40 669000000 Hz 4.2 dBmV 44.7 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 2 5120 Ksym/sec 29200000 Hz 42.0 dBmV 2 Locked ATDMA 1 5120 Ksym/sec 35600000 Hz 42.0 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 22800000 Hz 41.8 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 16400000 Hz 41.8 dBmV 5 Not Locked Unknown 0 0 0 0.0 dBmV 6 Not Locked Unknown 0 0 0 0.0 dBmV 7 Not Locked Unknown 0 0 0 0.0 dBmV 8 Not Locked Unknown 0 0 0 0.0 dBmV Downstream OFDM Channels Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 0 ,1 193 690000000 Hz 3.68 dBmV 44.1 dB 1228 ~ 2867 4057813 576682 0 2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Extended Upstream Transmit Power Enable Extended Upstream Transmit Power Current System Time:Thu Nov 04 13:49:23 2021 System Up Time:00:12:00
- lexneverlandJan 28, 2022Guide
I have the exact same issue. Whether using Linux, macOS, Windows 11, iOS or Android on 5 GHZ on my CAX80 I am unable to upload anything to iCloud or any other cloud server. This is very annoying and I haven't changed anything . Rebooted the router several times.
- FURRYe38Jan 28, 2022Guru - Experienced User
What FW version are you using?
Seems to be a problem with 5Ghz on current version, so you might try reverting back a version of FW on the CAX80.
- lexneverlandJan 29, 2022Guide
FURRYe38 I am on V2.1.3.5. The initiater of this thread was on previous firmware version when he was unable to upload on 5 GHz and the upgrade to V2.1.3.5 didn't resolve his issue.
Another thing I noticed is that upload is only blocked on (any) browser, not on cloud services like iCloud Drive or DropBox.And last: I rebooted the router yesterday and was able to upload on 5 GHz for a while and then it got blocked again.
