AlexanderSextus
Nov 04, 2021Star
CAX80 can't upload 5GHZ
Im having serious issues trying to get this figured out, ive tried playing with everything for teh last 6 hours to get my uploads to work in 5ghz mode. Im literally 25 feet from the router and any fi...
- Jun 14, 2023
Firmware version 5.1.1.2 is what everyone needs to push for to be released.
Nov 04, 2021Guru - Experienced User
Did you factory reset the modem and setup from scratch after you updated?
AlexanderSextus wrote:
Just updated and no luck. STILL have issues uploading to websites like Wetransfer.
However now dropbox is cool to upload to? now im super confused.
help.
Have you tried a different DNS provider?
- AlexanderSextusNov 04, 2021Star
Cable Diagnostic Status: Good Action: Your setup looks fine. If you are still experience an internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info. Internet Access: Downstream Status: Upstream Status: Refresh Save Cable Diagnostic Info Advanced Information Frequency Start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure Procedure Status Comment Acquire Downstream Channel 645 MHz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked 256 QAM 36 645000000 Hz 4.7 dBmV 45.5 dB 0 0 2 Locked 256 QAM 9 471000000 Hz 4.0 dBmV 45.9 dB 0 0 3 Locked 256 QAM 10 477000000 Hz 4.0 dBmV 45.7 dB 0 0 4 Locked 256 QAM 11 483000000 Hz 4.1 dBmV 45.8 dB 0 0 5 Locked 256 QAM 12 489000000 Hz 4.2 dBmV 45.7 dB 0 0 6 Locked 256 QAM 13 495000000 Hz 3.9 dBmV 45.5 dB 0 0 7 Locked 256 QAM 14 507000000 Hz 4.3 dBmV 45.8 dB 0 0 8 Locked 256 QAM 15 513000000 Hz 4.0 dBmV 44.6 dB 0 0 9 Locked 256 QAM 16 519000000 Hz 4.0 dBmV 38.2 dB 0 0 10 Locked 256 QAM 17 525000000 Hz 4.3 dBmV 42.2 dB 0 0 11 Locked 256 QAM 18 531000000 Hz 4.0 dBmV 43.0 dB 0 0 12 Locked 256 QAM 19 537000000 Hz 4.4 dBmV 44.4 dB 0 0 13 Locked 256 QAM 20 543000000 Hz 4.3 dBmV 45.4 dB 0 0 14 Locked 256 QAM 21 555000000 Hz 4.3 dBmV 42.1 dB 0 0 15 Locked 256 QAM 22 561000000 Hz 4.6 dBmV 36.4 dB 0 0 16 Locked 256 QAM 23 567000000 Hz 4.3 dBmV 41.0 dB 0 0 17 Locked 256 QAM 24 573000000 Hz 4.4 dBmV 39.3 dB 0 0 18 Locked 256 QAM 25 579000000 Hz 4.4 dBmV 43.1 dB 0 0 19 Locked 256 QAM 26 585000000 Hz 4.9 dBmV 45.7 dB 0 0 20 Locked 256 QAM 27 591000000 Hz 5.0 dBmV 45.8 dB 0 0 21 Locked 256 QAM 28 597000000 Hz 5.2 dBmV 45.9 dB 0 0 22 Locked 256 QAM 29 603000000 Hz 4.9 dBmV 45.8 dB 0 0 23 Locked 256 QAM 30 609000000 Hz 5.3 dBmV 45.9 dB 0 0 24 Locked 256 QAM 31 615000000 Hz 5.1 dBmV 45.8 dB 0 0 25 Locked 256 QAM 32 621000000 Hz 5.1 dBmV 45.6 dB 0 0 26 Locked 256 QAM 33 627000000 Hz 5.2 dBmV 45.1 dB 0 0 27 Locked 256 QAM 34 633000000 Hz 5.0 dBmV 44.8 dB 0 0 28 Locked 256 QAM 35 639000000 Hz 4.8 dBmV 45.2 dB 0 0 29 Locked 256 QAM 37 651000000 Hz 4.5 dBmV 45.3 dB 0 0 30 Locked 256 QAM 38 657000000 Hz 4.3 dBmV 45.2 dB 0 0 31 Locked 256 QAM 39 663000000 Hz 4.4 dBmV 45.2 dB 0 0 32 Locked 256 QAM 40 669000000 Hz 4.2 dBmV 44.7 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 2 5120 Ksym/sec 29200000 Hz 42.0 dBmV 2 Locked ATDMA 1 5120 Ksym/sec 35600000 Hz 42.0 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 22800000 Hz 41.8 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 16400000 Hz 41.8 dBmV 5 Not Locked Unknown 0 0 0 0.0 dBmV 6 Not Locked Unknown 0 0 0 0.0 dBmV 7 Not Locked Unknown 0 0 0 0.0 dBmV 8 Not Locked Unknown 0 0 0 0.0 dBmV Downstream OFDM Channels Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 0 ,1 193 690000000 Hz 3.68 dBmV 44.1 dB 1228 ~ 2867 4057813 576682 0 2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Extended Upstream Transmit Power Enable Extended Upstream Transmit Power Current System Time:Thu Nov 04 13:49:23 2021 System Up Time:00:12:00 - AlexanderSextusNov 04, 2021Star
Here are my speedtests...
I'm with Xfinity, my plan is 1200 Down & 35 Up
5G - Upload Spikes to 9Mbps then drops... ive even seen it settle @ 1.5Mbps.
DOWNLOAD Mbps409.81UPLOAD Mbps3.982.4GDOWNLOAD Mbps79.96UPLOAD Mbps15.92HARDWIREDDOWNLOAD Mbps923.67UPLOAD Mbps41.73 - AlexanderSextusNov 08, 2021Star
I had comcast send out a tech. We replaced teh Cable comming into my unit and still have issues. The problem here is with Netgear. And support is AWEFUL. Had to call multiple times and was told i would get a call back from higher level support and nothing.
I've never seen anything like this before and i've ALWAYS used netgear routers. Very disapointed.
for whatever its worth, the tech told me that he saw "FM noise", he was forign so his accent was a bit strong and i count exactly understand but he sure said noise and that the issue lies with teh unit.
what are the chances of having 2 bad systems? Im going to best buy to return this unit and get a 3rd... fingers crossed.
just to put my concerns to rest i went back to bestbuy and bought another CAX80... same issue.
NO IDEA what is going on here. Comcast is 100% good from teh tap to my home teh problem is with teh router, perhaps there is a setting that needs to altered. Im exhausted with this.
- FURRYe38Nov 08, 2021Guru - Experienced User
What is the brand and model# of these wifi adapters in the computers your using?
Have the drivers for these wifi adapters been updated?
Wondering if there is a problem between the CAX wifi and your wifi adapters.
I only have apple products.
2017 imac, and 2017 macbook pro all running latest macOS
I did have the issue on a windows 10 computer as well.
What is the brand and model of the wifi adapter on the Windows PC?
Ok. I guess I should try my CAX80 in router mode and see if my Mac Book Pro 2018 sees same thing.
What are the current wifi settings set for on the CAX?
Smart Connect enabled or disabled?
Channels being used?
WMM enabled or disabled?
Any Implicit Beamforming and MIMO enabled or disabled?
