AlexanderSextus
Nov 03, 2021Star
CAX80 can't upload 5GHZ
Im having serious issues trying to get this figured out, ive tried playing with everything for teh last 6 hours to get my uploads to work in 5ghz mode. Im literally 25 feet from the router and any fi...
- Jun 14, 2023
Firmware version 5.1.1.2 is what everyone needs to push for to be released.
Nov 26, 2021Guru - Experienced User
Does a wired connection exhibit the same thing?
tdalias wrote:
For the 5ghz network only, I'm having the same issue from my windows PC. I cannot upload to wetransfer.com/onedrive sync but I can do upload speed tests without visible issues.
I do not have this issue on my android phone using the same 5ghz network.
Disabling beamforming, MuMIMO, and AX does not resolve the issue. But it does upload more data before erroring.
Typically, it stops uploading at the 1MB mark.
Clean install of windows
Lastest cax80 firmware
No modem errors
Modem/computer have unobstructed line of site, about 20ft separation.
AlexanderSextus
Nov 26, 2021Star
Good luck.
Netgear support is trash. They didn’t hella me kept asking me to do the same BS resets every time. I still don’t have a solution and I bought 3 of the damn things to make sure it was a hardware issue. Seems to be a software one.
Comcast came to my place and replaced all the lines and confirmed all good. I will never buy another netgear product after they kept tying to sell me extended services after failing to solve this issue. If you can return it I suggest you do so.
- FURRYe38Nov 26, 2021Guru - Experienced User
I recommend you reach out to a forum moderator and let them know what your seeing.
AlexanderSextus wrote:
Good luck.
