AlexanderSextus
Nov 03, 2021Star
CAX80 can't upload 5GHZ
Im having serious issues trying to get this figured out, ive tried playing with everything for teh last 6 hours to get my uploads to work in 5ghz mode. Im literally 25 feet from the router and any fi...
- Jun 14, 2023
Firmware version 5.1.1.2 is what everyone needs to push for to be released.
tdalias
Nov 27, 2021Tutor
Actually, same issue on my android phone on the 5ghz network. It just gets to a larger upload size.
Dec 03, 2021Guru - Experienced User
Ok I put my CAX80 online in router mode today from Modem only mode.
Updated FW to v2.1.3.5.
1. I attempted to use the ERASE function on the CAX80 web page however after it rebooted, the LAN IP address had not changed back to 192.168.1.1. Hmmm.
I went ahead and setup the router and wifi SSID. Manual channel 11 and 40. Smart Connect, AX, MIMO, Beamforming and OFDMA enabled. Mixed WPA2 and WPA3 mode set. I powered OFF the modem for a good minute then back ON.
2. I noticed that the higher 5Ghz channels are missing from the UI:
3. Wired speed testing is good and to spec for my ISP services:
4. Wireless on two different wifi client adapters is not to spec on the upload. Should be at 50Mbps. I'm not seeing that:
Connection rate on my ASUS in wifi bridge mode is good:
The ASUS has testing out on other routers and gets to spec speeds on the up so I know it's not the ASUS.
I connected a D-Link DWA-192 and got around 30Mbps on the uplink, still not 50Mbs.
I have RAX500 that i'll set up as a wifi client and test with the CAX80.
The low uplink speed maybe causing problems.
- FURRYe38Dec 05, 2021Guru - Experienced User
Ok so testing my RAXE500 wireless bridge mode on 5Ghz with the CAX80 both far and close distances, uplink speed tests are bad and not to spec:
RAXE500: 20ft distance
RAXE500 at 8 feet distance from the CAX80:
A Macbook Pro 2018 native wifi:
- FURRYe38Dec 08, 2021Guru - Experienced User
Ok so I disabled the wifi on the CAX80. Got tired of seeing notifications that one of my cameras kept going off line every so often. Even after disabling AX mode and changing channels.
I'm now using a XR450 in AP mode and two EX7700s for additional coverage. No wifi issues anymore.
