AlexanderSextus
Nov 04, 2021Star
CAX80 can't upload 5GHZ
Im having serious issues trying to get this figured out, ive tried playing with everything for teh last 6 hours to get my uploads to work in 5ghz mode. Im literally 25 feet from the router and any fi...
- Jun 14, 2023
Firmware version 5.1.1.2 is what everyone needs to push for to be released.
Aug 30, 2022Guru - Experienced User
What FW version are you using?
NG is aware of the problem. Were hoping that next FW version will resolve this. I tested a beta and it fixed this issue however, presented a different problem on my modem which I had to send in my modem to get it fixed so I don't recommend using the beta version. I don't know when new FW will be forthcoming.
Just what works best for now.
AshleyTQ wrote:
I am having this same exact issue. Xfinity has been out twice to check all the lines and no issues there. I have also factory reset my router and nothing changed. This started happening mid August 2022. I can email attachments, but I can't even upload a small screenshot to Slack unless I use 2.4G or the wire
AshleyTQ
Aug 30, 2022Guide
Yeah I have a workaround so I'm not too fussed, but I work from home so it has caused me a number of issues.
I have v2.1.3.5 and it says there are no updates available
- FURRYe38Aug 30, 2022Guru - Experienced User
Ok. Keep whats loaded for now. Hopefully NG will come out with something. No idea when though.
- AshleyTQAug 30, 2022Guide
Thanks for your help and time! It's just really annoying when I bought my router a little over a year ago and spent a lot of money on it.
Understand. Will keep on them about this. From what I know, there is a fix, just needs to get into good working FW.
Keep an eye on the NG download page or here in this forum.
Thanks again! I work in customer service for a software company so I get it 🙂
Thanks for understanding. We get the users frustrations as well. 😉
- lexneverlandSep 11, 2022Guide
I returned the Motorolla router/modem and of course afterwards my upload issues started again on 5GHz. Good to know, however, that there will be a fix soon. Is there a way to be automatically notified when a new FW is available?
- FURRYe38Sep 11, 2022Guru - Experienced User
Not that a I know of. Keep an eye on the NG download page or here in the forums.
Thanks, will make a weekly reminder to check.
- FURRYe38Sep 20, 2022Guru - Experienced User
- AshleyTQSep 20, 2022Guide
Thanks so much for sending this over, but it looks like they may have rolled it back. I can't access the link and my app is still telling me there is no update available.
Link is good. This update has to be manually installed using a PC and web browser.
So weird, this is what I get. But I am on a Mac and not a PC if that makes a difference
I logged into routerlogin.net and tried to update from there and nothing was available
I also downloaded Firmware Version 2.1.4.2 https://www.netgear.com/support/download/?model=CAX80
and looked for the file ending in either .img or .chk per https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
But I only have Release Notes and CAX80-V2.1.4.2.bin in the zip file
Interesting.
The .bin file is what you use with a web browser when connected to the CAX web page and using the FW update web page to select this .bin file from your PC to upload to the router side of the modem. Do not attempt to open the .bin file. It gets sent thru the modems web page using the web browser.
- AshleyTQSep 21, 2022Guide
Thank you and please excuse my ignorance as I've never had to do this before. On http://www.routerlogin.net I go to Advanced -> Router Update and browse for the .bin file and upload it here?
When I click the "Check" button above Browse it tells me "No New Firmware Version Available."
- FURRYe38Sep 21, 2022Guru - Experienced User
Yes, Select the browse button and navigate out to where the .bin file is located. Once selected, press the UPLOAD button.
Thanks so much! I'll try that later today
I really appreciate all your help on this
- Reed123456Sep 29, 2022Guide
Hi, I was wondering if this solution worked for the others on this thread. I am also experiencing this issue and made the update to V2.1.4.2 and it still doesn't seem to be working. Does anyone have any other advice?
- bossboarOct 12, 2022Initiate
I have the same problem with the latest FW 2.1.4.2... This FW doesn't solve the upload issue with the 5GHz network. So disappointment.
- lexneverlandOct 17, 2022Guide
bossboar tdalias Reed123456 AshleyTQ
Do you all have Comcast Xfinity as ISP? Can you please confirm? This was the common denominator for all the users who experienced this 5GHz upload issue in another thread. - AshleyTQOct 17, 2022GuideYes that is exactly who I have
- FURRYe38Oct 17, 2022Guru - Experienced User
The issue has been reviewed and addressed by NG. Just waiting next FW update. Fixes don't come over night. Users will need to be patient.
