AlexanderSextus
Nov 04, 2021Star
CAX80 can't upload 5GHZ
Im having serious issues trying to get this figured out, ive tried playing with everything for teh last 6 hours to get my uploads to work in 5ghz mode. Im literally 25 feet from the router and any fi...
- Jun 14, 2023
Firmware version 5.1.1.2 is what everyone needs to push for to be released.
Sep 20, 2022Guru - Experienced User
Link is good. This update has to be manually installed using a PC and web browser.
AshleyTQ
Sep 20, 2022Guide
So weird, this is what I get. But I am on a Mac and not a PC if that makes a difference
I logged into routerlogin.net and tried to update from there and nothing was available
I also downloaded Firmware Version 2.1.4.2 https://www.netgear.com/support/download/?model=CAX80
and looked for the file ending in either .img or .chk per https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
But I only have Release Notes and CAX80-V2.1.4.2.bin in the zip file
