AlexanderSextus
Nov 03, 2021Star
CAX80 can't upload 5GHZ
Im having serious issues trying to get this figured out, ive tried playing with everything for teh last 6 hours to get my uploads to work in 5ghz mode. Im literally 25 feet from the router and any fi...
- Jun 14, 2023
Firmware version 5.1.1.2 is what everyone needs to push for to be released.
Retired_Member
May 20, 2023It may have taken so many years, but I think I finally figured out.
Check to make sure that any devices that are having this upload issue, don't have their network settings set to use MAC Randomization.
If you turn that off on any of your devices having the problem, does that make it work properly again?
May 21, 2023Guru - Experienced User
That could be one possible cause.
However, others have seen usses with PC wifi adapters, items that don't use any MAC ADDRESS randomization.
- yatman60May 22, 2023Star
Update::
I've been working very closely with the team at Netgear to get this issue resolved. I can't say too much as I had to sign an NDA but keep an eye out for a software update coming in the near future. I'm no longer experiencing issues on 5G.- naveennelluriMay 22, 2023Aspirantyatman60 I'm all in to try any beta software, that fixes it. It's strange to need an NDA, as this is not new software or hardware, but merely a bug fix, that's plaguing everyone apparently. But what do i know. Eagerly waiting and fingers crossed. Thanks for the update.
- lexneverlandJun 08, 2023Guide
Well, I won't be holding my breath. yatman60 I will believe it when I see it. I have spent so much time with Netgear engineers, customer service reps, here in the forums.
Any word on when this firmware update is being released?
- MrhoohaJun 16, 2023AspirantCan I get this fix? I am having this issue.
- XelliousJun 17, 2023TutorI just bought a CAX80 and running into issues with the 5ghz when uploading and working with the Microsoft Azure portal. 80% of the time I load a resource page there is an api call failure and it can't get the resource info. I have 0 issues on the 2.4ghz network and have tried all posted troubleshooting steps with no luck.
This is absolutely ridiculous.
