AlexanderSextus
Nov 03, 2021Star
CAX80 can't upload 5GHZ
Im having serious issues trying to get this figured out, ive tried playing with everything for teh last 6 hours to get my uploads to work in 5ghz mode. Im literally 25 feet from the router and any fi...
- Jun 14, 2023
Firmware version 5.1.1.2 is what everyone needs to push for to be released.
My_Username
Aug 04, 2023Apprentice
I am also having several issues related to the inability to upload files of any significant size over a 5GHz WiFi connection. I am reasonably certain my issues are caused by this WiFi glitch. I am running FW 2.1.5.2. My provider is Comcast and my connection is 1Gb. Connection status is all-good.
Based on advice given in this thread I just finished a very frustrating call with Netgear support. I was told that 2.1.5.2 is the latest firmware and there is no beta or later version.
I appreciate the attention this issue is getting and the documentation on this forum.
What do I need to do to obtain a copy of this beta firmware. Netgear has been no help.
- FURRYe38Aug 05, 2023Guru - Experienced User
Contact NG support.
- My_UsernameAug 13, 2023Apprentice
Seems you didn't read my post. Issue solved through the actions of others.
- FURRYe38Aug 14, 2023Guru - Experienced User
Seems that Users have already contacted NG support and got the beta FW. From the posts they have been posting about. NG helped those users.
