RAbbott32
Apr 25, 2023Aspirant
CAX80 Completely Bricked - Only Power Light On
I'm having an issue I see that popped up a lot in the past year on this forum - I have a bricked CAX80 that has only the power LED light on. Hard reset does not work, the unit is entirely unresponsiv...
Apr 26, 2023Guru - Experienced User
I struggle a bit with "stand by their products".
They do. That's what a warranty is.
I haven't seen any company that standardly replaces their products when they're a year out of warranty.
They'd go out of business. Its why you have a set warranty period and you have to pay for extended warranties if you want to gamble. Feel free to try other networking companies if you think they'll extend their warranty out a year for free.
In terms of your device. did you try disconnecting the coax from it and pushing and holding reset for up to 30 seconds while powered on?
You could also try recovering it with tftp if you feel its a corrupt firmware issue.
RAbbott32
Apr 26, 2023Aspirant
Netgear caused the brick with their pushed firmware and it has affected many customers. Yes, companies tend to compensate customers when they are the sole cause of a product failure. Regarding your recommendations, it appears you did not read my message as I tried each of those things mentioned and the product is entirely unresponsive - again, due to firmware pushed by Netgear.
