RAbbott32
Apr 25, 2023Aspirant
CAX80 Completely Bricked - Only Power Light On
I'm having an issue I see that popped up a lot in the past year on this forum - I have a bricked CAX80 that has only the power LED light on. Hard reset does not work, the unit is entirely unresponsiv...
RAbbott32
Apr 26, 2023Aspirant
Netgear caused the brick with their pushed firmware and it has affected many customers. Yes, companies tend to compensate customers when they are the sole cause of a product failure. Regarding your recommendations, it appears you did not read my message as I tried each of those things mentioned and the product is entirely unresponsive - again, due to firmware pushed by Netgear.
Apr 26, 2023Guru - Experienced User
I've passed this on to NG.
- RAbbott32May 01, 2023Aspirant
Providing an update to those with the same issue and following:
DarrenM did elevate the issue and I received a message from customer support requesting a time to discuss the issue on the phone, but this request has not been genuine and has been a complete end-around. I provided them four separate times I was available for a call and did not receive a call at any time. The only other message from support was "sorry we didn't call you, can you provide two more times?" after they ignored the first two times. Then they ignored the second two.
Unfortunately it appears their approach is just to ignore/exasperate and not actually provide support. Since the CAX80 firmware bricking is a known issue where Netgear is causing $500 in damages to its customers by pushing faulty firmware then not addressing the issue I have submitted complaints to the FTC and FCC explaining the problem and that it is widespread to many customers on this board and others. I am also working with my bank to claw back the funds from the defective product since Netgear's support, again, refuses communication. I will update this if Netgear support actually does make an attempt to reach out on the 5th or more times they ask to.
