Svalent
Nov 10, 2020Tutor
CAX80 connected but no internet Xfinity
I just recieved the CAX80 yesterday and called Xfiinity to get it hooked up. It's online but I can't connect to the internet. Xfinity confirmed that it is working on their end. My phone shows that it...
Nov 10, 2020Guru - Experienced User
Does a wired PC connected to the modems back ports work?
Try a factory reset and setup from scratch using a wired PC.
Be sure your mobile devices is setup for automatic IP addressing configuration. Not static on the mobile device.
Svalent
Nov 10, 2020Tutor
I haven't tried hooking up to a wired connection yet. I'll try that when i get home today
- FURRYe38Nov 10, 2020Guru - Experienced User
When you connect a wired PC, use a web browser and access the modems web page at 192.168.100.1
I'd check the wireless SSID name and PW and check the status on the Basic and Advanced Tab home page as well.
