Svalent
Nov 10, 2020Tutor
CAX80 connected but no internet Xfinity
I just recieved the CAX80 yesterday and called Xfiinity to get it hooked up. It's online but I can't connect to the internet. Xfinity confirmed that it is working on their end. My phone shows that it...
Svalent
Nov 10, 2020Tutor
So I did the factory reset and then disconnected everything and plugged it in and hooked up an ethernet to my laptop. At first the internet still didn't work even though it was hard wired. I logged into the modem and was just going through the menus and then after about 5-10 minutes I tried the internet again and it was working. Youtube was working. So I logged in with my phone and wifi is now working on my phone. Here is a copy and paste of the cable log. Now I'm trying speed tests and I'm not impressed. On 5G on my phone it was a little over 100mbps download speed and each time I test it, it is getting less. I have the 1000mbps plan from Xfinity so I should be getting a lot better. I ran the speed test on my laptop and it is hard wired and download speede was 434. Then I tested again a few minutes later and it was 104. I just tried again and now I got 460. shouldn't I be getting at least double that? should I reset the modem again?
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
Startup Procedure
| Procedure | Status | Comment |
| Acquire Downstream Channel | 447 MHz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enabled | BPI+ |
Downstream Bonded Channels
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
| 1 | Locked | 256 QAM | 8 | 447000000 Hz | -2.0 dBmV | 40.6 dB | 0 | 0 |
| 2 | Locked | 256 QAM | 9 | 453000000 Hz | -2.6 dBmV | 40.5 dB | 0 | 0 |
| 3 | Locked | 256 QAM | 10 | 459000000 Hz | -2.4 dBmV | 40.5 dB | 0 | 0 |
| 4 | Locked | 256 QAM | 11 | 465000000 Hz | -2.8 dBmV | 40.3 dB | 0 | 0 |
| 5 | Locked | 256 QAM | 12 | 471000000 Hz | -3.0 dBmV | 40.2 dB | 0 | 0 |
| 6 | Locked | 256 QAM | 13 | 477000000 Hz | -2.6 dBmV | 40.3 dB | 0 | 0 |
| 7 | Locked | 256 QAM | 14 | 483000000 Hz | -2.5 dBmV | 40.4 dB | 0 | 0 |
| 8 | Locked | 256 QAM | 15 | 489000000 Hz | -2.2 dBmV | 40.5 dB | 0 | 0 |
| 9 | Locked | 256 QAM | 16 | 495000000 Hz | -1.6 dBmV | 40.7 dB | 0 | 0 |
| 10 | Locked | 256 QAM | 17 | 507000000 Hz | -1.4 dBmV | 40.8 dB | 0 | 0 |
| 11 | Locked | 256 QAM | 18 | 513000000 Hz | -1.4 dBmV | 40.4 dB | 0 | 0 |
| 12 | Locked | 256 QAM | 19 | 519000000 Hz | -1.2 dBmV | 40.5 dB | 0 | 0 |
| 13 | Locked | 256 QAM | 20 | 525000000 Hz | -1.0 dBmV | 40.8 dB | 0 | 0 |
| 14 | Locked | 256 QAM | 21 | 531000000 Hz | -0.9 dBmV | 40.8 dB | 0 | 0 |
| 15 | Locked | 256 QAM | 22 | 537000000 Hz | -1.1 dBmV | 40.8 dB | 0 | 0 |
| 16 | Locked | 256 QAM | 23 | 543000000 Hz | -1.2 dBmV | 40.6 dB | 0 | 0 |
| 17 | Locked | 256 QAM | 24 | 549000000 Hz | -0.9 dBmV | 40.7 dB | 0 | 0 |
| 18 | Locked | 256 QAM | 25 | 555000000 Hz | -0.7 dBmV | 40.8 dB | 0 | 0 |
| 19 | Locked | 256 QAM | 26 | 561000000 Hz | -0.8 dBmV | 40.8 dB | 0 | 0 |
| 20 | Locked | 256 QAM | 27 | 567000000 Hz | -0.9 dBmV | 40.8 dB | 0 | 0 |
| 21 | Locked | 256 QAM | 28 | 573000000 Hz | -1.0 dBmV | 40.7 dB | 0 | 0 |
| 22 | Locked | 256 QAM | 29 | 579000000 Hz | -0.9 dBmV | 40.6 dB | 0 | 0 |
| 23 | Locked | 256 QAM | 30 | 585000000 Hz | -0.4 dBmV | 40.7 dB | 0 | 0 |
| 24 | Locked | 256 QAM | 31 | 591000000 Hz | 0.0 dBmV | 40.6 dB | 0 | 0 |
| 25 | Locked | 256 QAM | 32 | 597000000 Hz | 0.1 dBmV | 40.5 dB | 0 | 0 |
| 26 | Locked | 256 QAM | 33 | 603000000 Hz | 0.1 dBmV | 40.6 dB | 0 | 0 |
| 27 | Locked | 256 QAM | 34 | 609000000 Hz | -0.2 dBmV | 40.4 dB | 0 | 0 |
| 28 | Locked | 256 QAM | 35 | 615000000 Hz | -0.3 dBmV | 40.3 dB | 0 | 0 |
| 29 | Locked | 256 QAM | 36 | 621000000 Hz | 0.0 dBmV | 40.3 dB | 0 | 0 |
| 30 | Locked | 256 QAM | 37 | 627000000 Hz | 0.0 dBmV | 40.4 dB | 0 | 0 |
| 31 | Locked | 256 QAM | 38 | 633000000 Hz | 0.0 dBmV | 40.3 dB | 0 | 0 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
Upstream Bonded Channels
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 4 | 5120 Ksym/sec | 36700000 Hz | 42.0 dBmV |
| 2 | Locked | ATDMA | 1 | 5120 Ksym/sec | 17300000 Hz | 43.3 dBmV |
| 3 | Locked | ATDMA | 2 | 5120 Ksym/sec | 23700000 Hz | 42.5 dBmV |
| 4 | Locked | ATDMA | 3 | 5120 Ksym/sec | 30300000 Hz | 42.5 dBmV |
| 5 | Locked | ATDMA | 5 | 1280 Ksym/sec | 41200000 Hz | 45.8 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
Downstream OFDM Channels
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0 ,1 ,2 ,3 | 48 | 850000000 Hz | -3.82 dBmV | 39.4 dB | 1108 ~ 2987 | 27482454 | 22121270 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | 0 dB | 0 ~ 4095 | 0 | 0 | 0 |
Upstream OFDMA Channels
| 1 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV |
Extended Upstream Transmit PowerEnable Extended Upstream Transmit Power
Current System Time:Tue Nov 10 16:46:59 2020System Up Time:00:17:23
Nov 10, 2020Guru - Experienced User
Are you using smart connect? if so, the cax80 might have your iphone on the 2.4ghz which is much slower and sensitive to interference.
On your laptop, how are you testing? Many sites won't saturate gigabit. try speedtest.xfinity.com
Also, what laptop are you testing on? some older devices won't saturate gigabit.
