FizzyOtter
Jun 21, 2023Tutor
CAX80 constant restarts and factory resets.
Good evening. I've been having an issue for the past month and a half with my Cax80. I bought it last year and it worked pretty well for about a year until about a month and a half ago. I realized t...
michaelkenward
Jun 22, 2023Guru - Experienced User
Wrong place to ask.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Gateways - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
