Jjoshrtca
Oct 09, 2020Guide
CAX80 DHCP not working
Like the title says. I’m just gonna repost lurksalot post from the link since it sums everything up that I and others are experiencing. https://community.netgear.com/t5/Cable-Modems-Routers/Cax80-k...
Oct 09, 2020Guru - Experienced User
Is AX mode enabled? What happens if you turn OFF AX mode?
Try setting a IP address reservation ON the CAX for your wifi device.
What DHCP IP address pool range are you using? Default? Try setting a smaller size. 192.168.1.100 thru .200.
What wifi devices do you have? Mfr and model#
Jjoshrtca
Oct 12, 2020Guide
Setting dhcp suffix to 100-200 broke it. No device can load anything now. Might just say f it and return this pos.
