klimchuk
Feb 08, 2021Aspirant
CAX80 doesn't save settings
I just found that my CAX80 lost password after reboot, password works after change until next reboot But newly create port-forwading doesn't work at all even though it's listed in UI, new port forw...
- Feb 11, 2021
What browser are you usuing? Try IE11, Edge, Firefox or Opera
Feb 11, 2021Guru - Experienced User
klimchuk
Feb 12, 2021Aspirant
Thank you for reply!
Eventually I did factory reset and now it's working fine.
It was pain to get all custom configuration back though
- FURRYe38Feb 12, 2021Guru - Experienced User
Make sure you do a back up configuration to file for safe keeping. Saves time if a reset is neede. Please mark your thread as solved so others will know.
Enjoy.
