plzhelprouter
Jan 25, 2025Aspirant
CAX80 Doesnt Save Settings
CAX80 doesn't save settings. I have the latest firmware. I have done the manual reset of the router by sticking a pin in the hole and reconfigured it. If power ever drops, or you click "reboot rou...
Jan 26, 2025Guru - Experienced User
It should save the settings. Try reinstalling the latest firmware, then factory reset, and then reinstall it. Don't install from a backup.
What actual version of firmware are you on?
plzhelprouter
Jan 26, 2025Aspirant
Latest Firmware V5.1.1.8. Did all you said (multiple times even) and still doesn't save settings upon reboot and have to renter all info again (as per usual thus far).
Have tried via Firefox, Brave, and Chrome - all w/ the same result - settings dont save have to manually resetup eveything.
Is this a normal subnetmask for Internet connection tab???
In the LAN section this is my subnet
Why wont this router save settings??
