AJPO
Feb 03, 2024Tutor
Cax80 Drops Connection, But Wifi Works.
I have a cax80 wifi modem and a 1.2 GB Comcast Connection. The modem drops the connection to my pc that is connected via ethernet cable. Sometimes the connection will be fine for several hours, then ...
Feb 04, 2024Guru - Experienced User
What firmware version do you have installed?
there was an earlier one or two that had issues with the 2.5gig connection
- AJPOFeb 04, 2024Tutor
Firmware version V2.1.5.2
Cable Firmware version V1.02.08
Comcast has refused to push any firmware updates. It can be very difficult to get a comcast tech on the phone that has much of a clue. Appreciate the response.
