DeRock25
Oct 28, 2021Aspirant
CAX80 Ethernet aggregation and 2.5g port SLOW
Have a Dell Powerconnect 5048 with sfp+ copper 1g/2.5g/10g plug ins. have 900mbps internet speeds. dell 5048 on latest firmware available sfp+ adapters recognized as 10g capable speedtest.n...
Oct 29, 2021Guru - Experienced User
Kinda hard to tell if this is a modem or other issue. You might test with two 2.5Gb LAN adapters to help rule out the SFP at some point.
I presume since your only seeing just over 900Mpbs, that using the 2.5Gb WAN port is all thats needed and LAG isn't really needed. I have same ISP speed and don't use LAG. Mine in modem only mode though.
- DeRock25Oct 29, 2021Aspirant
using the sfp to the regular gig port gives full speeds... i just get lower speeds with the 2.5g port to 2.5g and the LAG(the lag is absolutly rediculously unreliable speeds)... which if things keep going the way they are.. in another 6 months they will up my speed again above 1g...
i have tried 2 different sfp adapters, both sfp ports...
my house has a large number of devices and lots of 4k streaming.. so i was working to maximize network capabilites... don't have any 2.5g devices besides the switch...
is it most likely that since my sfp+ port is only 1/10g that the sfp+ adapter model that is suppose to do the adapting is just crap?
amazon purchased adapter stated compatible....
