freddieb91
May 01, 2025Aspirant
Cax80 ethernet port went out
hello im having trouble with my cax80 this morning the t=ethernet ports just went out and ive done the soft reset hard reset and tried new cables but the only thing that is showing is the 2 port on t...
freddieb91
May 02, 2025Aspirant
The led number 2 lights up and then cuts off the other ethernet ports are not working besides the multigig port
May 02, 2025Guru - Experienced User
Ok. That helps. You're showing locked in. Can you access it via wifi?
Did you try other cables? And different devices?
How old is it?
