Retired_Member's avatar
Retired_Member
Nov 01, 2021
CAX80 ethernet to Wink2 hub
Greetings, AX6000 (CAX80) will not connect to the Wink2 Hub using an ethernet cable, it works fine in wifi mode. I lose the connection when I plug an ethernet cable into the hub and then into the ca...
