Retired_Member
Nov 01, 2021CAX80 ethernet to Wink2 hub
Greetings, AX6000 (CAX80) will not connect to the Wink2 Hub using an ethernet cable, it works fine in wifi mode. I lose the connection when I plug an ethernet cable into the hub and then into the ca...
Nov 01, 2021Guru - Experienced User
I would contact the Mfr of the Wink hub device and ask for help and information regarding there product.
Retired_Member
Nov 07, 2021FURRYe38,
I contacted Wink several times without a solution to my problem, they are not the easiest tech support to work with (email only and not very quick with answers). Lou F.
