Dana259
Jun 25, 2022Aspirant
CAX80 has no wifi now.
I pushed the Wifi button to turn it on/ off but nothing.
- Jun 26, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jun 25, 2022Guru - Experienced User
Press the reset button on the back of the modem for 10 seconds then release then setup from scratch.
Does the default setup SSID name appear on a wifi device?
- Dana259Jun 25, 2022AspirantNo name shows up on wifi
- Dana259Jun 25, 2022AspirantResetting again to see if works.
- Dana259Jun 25, 2022AspirantWifi is back after reset. Thanks
- FURRYe38Jun 26, 2022Guru - Experienced User
Enjoy. 📡
