Dana259
Jun 25, 2022Aspirant
CAX80 has no wifi now.
I pushed the Wifi button to turn it on/ off but nothing.
- Jun 26, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Dana259
Wifi is back after reset. Thanks
Jun 26, 2022Guru - Experienced User
Enjoy. 📡
