afitz485
Aug 08, 2022Tutor
CAX80 has open port from WAN side
Hi I am testing my new CAX80 from the WAN side using several firewall tester websites. I found one open port and would like to close it. I tried blocking the TCP port using CAX80's Advanced -> ...
Aug 08, 2022Guru - Experienced User
Did you check out what that port is and whats recommended for disabling it?
https://www.speedguide.net/port.php?port=7547
- afitz485Aug 08, 2022Tutor
Thanks for the link. They recommend disabling TR-069 in the router or port forwarding it to an unused IP address. I will try these approaches and see how it goes.
Thanks.
