90sScott
Dec 16, 2020Aspirant
CAX80 Internet cuts out everyday
Hey Friends, My internet access wired and wifi seems to go down everyday at the same time. Thought it was the DHCP lease renewing but that's on a 7 day timer, a simple reboot of the router fixes ...
90sScott
Seems to cut out at 10am CST everyday tried changing the network clock and the cut out shifted as expected to 6am
Cable Connections:
| requency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
Startup Procedure
| Procedure | Status | Comment |
| Acquire Downstream Channel | 609 MHz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enabled | BPI+ |
Downstream Bonded Channels
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
| 1 | Locked | 256 QAM | 16 | 609000000 Hz | 5.3 dBmV | 41.8 dB | 0 | 0 |
| 2 | Locked | 256 QAM | 1 | 519000000 Hz | 6.0 dBmV | 41.3 dB | 0 | 0 |
| 3 | Locked | 256 QAM | 2 | 525000000 Hz | 6.0 dBmV | 40.0 dB | 0 | 0 |
| 4 | Locked | 256 QAM | 3 | 531000000 Hz | 6.0 dBmV | 40.8 dB | 0 | 0 |
| 5 | Locked | 256 QAM | 4 | 537000000 Hz | 5.7 dBmV | 41.4 dB | 0 | 0 |
| 6 | Locked | 256 QAM | 5 | 543000000 Hz | 5.7 dBmV | 42.1 dB | 0 | 0 |
| 7 | Locked | 256 QAM | 6 | 549000000 Hz | 5.8 dBmV | 42.3 dB | 0 | 0 |
| 8 | Locked | 256 QAM | 7 | 555000000 Hz | 5.5 dBmV | 42.2 dB | 0 | 0 |
| 9 | Locked | 256 QAM | 8 | 561000000 Hz | 5.2 dBmV | 41.9 dB | 0 | 0 |
| 10 | Locked | 256 QAM | 9 | 567000000 Hz | 5.1 dBmV | 41.6 dB | 0 | 0 |
| 11 | Locked | 256 QAM | 10 | 573000000 Hz | 5.2 dBmV | 41.4 dB | 0 | 0 |
| 12 | Locked | 256 QAM | 11 | 579000000 Hz | 4.7 dBmV | 41.7 dB | 0 | 0 |
| 13 | Locked | 256 QAM | 12 | 585000000 Hz | 4.7 dBmV | 40.9 dB | 0 | 0 |
| 14 | Locked | 256 QAM | 13 | 591000000 Hz | 4.6 dBmV | 41.1 dB | 0 | 0 |
| 15 | Locked | 256 QAM | 14 | 597000000 Hz | 4.6 dBmV | 41.1 dB | 0 | 0 |
| 16 | Locked | 256 QAM | 15 | 603000000 Hz | 4.8 dBmV | 41.5 dB | 0 | 0 |
| 17 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 18 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 19 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 20 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 21 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 22 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 23 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 24 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 25 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 26 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 27 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 28 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 29 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 30 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 31 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
Upstream Bonded Channels
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 4 | 5120 Ksym/sec | 36800000 Hz | 37.0 dBmV |
| 2 | Locked | ATDMA | 5 | 5120 Ksym/sec | 30350000 Hz | 36.5 dBmV |
| 3 | Locked | ATDMA | 6 | 5120 Ksym/sec | 23900000 Hz | 36.5 dBmV |
| 4 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
Downstream OFDM Channels
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0 ,1 ,2 ,3 | 159 | 651000000 Hz | 7.38 dBmV | 40.9 dB | 646 ~ 3449 | 17957958 | 671002 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | 0 dB | 0 ~ 4095 | 0 | 0 | 0 |
Upstream OFDMA Channels
| 1 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV |
