90sScott
Dec 16, 2020Aspirant
CAX80 Internet cuts out everyday
Hey Friends, My internet access wired and wifi seems to go down everyday at the same time. Thought it was the DHCP lease renewing but that's on a 7 day timer, a simple reboot of the router fixes ...
Dec 16, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
90sScott
Have already had the isp run all checks and had a tech come out. Everything looks good on the ISP side they’re not seeing any service errors in their system.
- FURRYe38Dec 16, 2020Guru - Experienced User
- 90sScottDec 16, 2020AspirantFW version 2.1.1.4 most up to date per net gear website. Came loaded with it. Have checked multiple times for an update since I installed this 7 days ago.
Have factory reset twice with a clean set up on a hardwired laptop. Still no fix.
NG support has had me change wireless channels, check ping, reboot, and reset multiple times. Maybe just a defective unit?- FURRYe38Dec 16, 2020Guru - Experienced User
What speed package do you pay for from your ISP?
I see your down channel are only locked in to 16. I presume you don't have 1Gb ISP services?
All this seen even before the recent FW update? If so, I presume you may have a bad unit that needs to be replaced.
I've had mine since last year and has worked well. Also had two EX7700s connectes for more wifi coverage. I've only recently took it off line to put my CM1200 online to work with it and my Orbi AX system. Otherwise my CAX80 has been great.
