BEB7474
Aug 23, 2020Star
Cax80 keeps dropping internet connection
Recently purchased Nighthawk CAX80. Never had problems w/ my internet connection before hooking up the Cax80. For last 2 wks since my Cax80 has been connected, im getting disconnected like every 20 mi...
Aug 23, 2020Guru - Experienced User
What firmware is on the router aspect? (the cax80 has firmware for modem and for the router)
Do you have a screen snip of the cable connections page (all of it) and the modem logs? it helps us see if its a line issue.
If you have any coax splitters, amplifiers, or attenuators in line, try it with them removed. Also check the coax for bad/cheap connections, kinked/damaged wire, extended runs, etc.
BEB7474
Sep 13, 2020Star
Thank you for responding. Im not using a splitter or anything extra. I have my streaming box connected via ethernet & phone is connected via wifi. I took a pic of firmware. Not sure where to find modem firmware. Any advice would be great
