BEB7474
Aug 23, 2020Star
Cax80 keeps dropping internet connection
Recently purchased Nighthawk CAX80. Never had problems w/ my internet connection before hooking up the Cax80. For last 2 wks since my Cax80 has been connected, im getting disconnected like every 20 mi...
Sep 13, 2020Guru
do you have a screen snip of the cable connections page and the logs?
BEB7474
Sep 23, 2020Star
How can I get that? Everything loses connection. I took a screenshot of my internet port settings. My ISP said my signal is very strong. They came out & chkd my connections & said everything was good on their end &my end.
- FURRYe38Sep 23, 2020Guru
Post a screen capture from the modems web page under Cable Connections. There could be too much power on the line as well.
My CAX80 has been running great for me. Most issues are ISP and signal on the cable line releated.
- BEB7474Sep 24, 2020StarScreen shot of cable connection settings is attached. Ive lived here for 5 yrs & never had a problem, EVER. My At&T wifi worked flawless. I have Cox now & it worked perfect w/ their modem/router.
- plemansSep 24, 2020Guru
You need to get all the info off the connections page. not just the little bit your screen shot had.
