BEB7474
Aug 23, 2020Star
Cax80 keeps dropping internet connection
Recently purchased Nighthawk CAX80. Never had problems w/ my internet connection before hooking up the Cax80. For last 2 wks since my Cax80 has been connected, im getting disconnected like every 20 mi...
cwdancer42
Feb 28, 2021Aspirant
When i installed the modem/router. I had Infinity here. they just installed the service. They stayed until the Router was setup. My issue started about 3 months later with it dropping the wired ports, not WiFi. I could always connect to the WiFi and have internet. Rebooting router or waiting 3 to 5 min would restore the LAN connections .
Feb 28, 2021Guru - Experienced User
Try the CAX80 with out the switch as well to see if the problem still happens.
