ewu297
Jun 10, 2022Initiate
CAX80 keeps factory resetting every time
Seriously this needs to be fixed in the newer model or a firmware update Currently - V2.1.3.7 had this issue since V2.1.1.4 Every time ISP disconnects due to maintenance or restarts the modem by...
Jun 10, 2022Guru - Experienced User
Try manually loading v.7 FW on the modem using Firefox or MS Edge browser. Once it's loaded, power OFF the modem by pulling the power brick for 1 full minute. Then back ON. After modem is ready, do a full factory reset and setup from scratch with same browser. I would use the ERASE button on the Backup menu page on the modems web page.
ewu297
Jun 13, 2022Initiate
Tried that already
-factory reset
-downloaded fresh firmware to install again
I believe the reason it keeps doing this is because the reset on/off button was removed. Hardware keep crashing due to packet loss or ISP is down
-factory reset
- FURRYe38Jun 15, 2022Guru - Experienced User
There should be a reset button in back. Do you see the reset button hole in back. If you press the reset button do you feel a momentary bump in the press or nothing at all? If nothing at all, I would contact NG support and ask about an RMA.
