Moreno279
Jun 11, 2022Aspirant
CAX80 keeps rebooting
For the past 3 days my CAX80 has been rebooting every 4 to 5 hours. I’ve tried connecting the power source directly to an outlet and that didn’t work. I did a factory reset and that also didn’t work. ...
jg62
Jun 15, 2022Star
Have same issue with fw v 2.1.3.7 causing reboots and then loss of admin creds and then [DoS attack] LAND Attack SPT:2190 DPT:2190 errors in the log. This is a very expensive device and so it should be fixed asap as most of us work from home for at least part of the time and so waiting long term for a fix on hardware that is still under warranty in my case is unacceptable.
I upgrade to this for the newer wifi standard and its claim to give better home coverage, but have connections dropping on far side of of a modest 2100 sqft home.all the time. Has been a real disappointment from the start and so I wish I had returned it when I could have but not 7 months in, so stuck with expensive below par gear.
milad6387
Jun 15, 2022Guide
jg62 : Do you have technical support remaining for your device? I suggest calling in or going online (https://my.netgear.com/support/contact.aspx) and opening a ticket.
This way we can get some more attention on this.
If you go online, you can reference this community post.
Thanks.
