Moreno279
Jun 11, 2022Aspirant
CAX80 keeps rebooting
For the past 3 days my CAX80 has been rebooting every 4 to 5 hours. I’ve tried connecting the power source directly to an outlet and that didn’t work. I did a factory reset and that also didn’t work. ...
milad6387
Jun 15, 2022Guide
jg62 : Do you have technical support remaining for your device? I suggest calling in or going online (https://my.netgear.com/support/contact.aspx) and opening a ticket.
This way we can get some more attention on this.
If you go online, you can reference this community post.
Thanks.
tamanaco
Jun 15, 2022Apprentice
As I review some of the recent posts/threads with CAX80 rebooting issues, the problem appears to be across all/most ISPs (Xfinity, Comcast and Spectrum) and the issue surfaced at about the same time as the reports in this community show. The common component in all the reports is the CAX80s with similar issues: - DoS Attacks messages on the log and the sudden appearance of a new firmware available notice when there's none. - Coincidence? I might be wrong... but this time I don't believe that the recent CAX80 rebooting issue is being caused by ISP's signal issue.
