Moreno279
Jun 11, 2022Aspirant
CAX80 keeps rebooting
For the past 3 days my CAX80 has been rebooting every 4 to 5 hours. I’ve tried connecting the power source directly to an outlet and that didn’t work. I did a factory reset and that also didn’t work. ...
kinghq1
Jun 19, 2022Star
tfc3000 let us know how this goes. The answer MAY be a new Router, but I'm not going to pay for it IF it is not an issue on my end. NG either needs to fix the firmware OR replace the router, pure and simple.
kinghq1
Jun 19, 2022Star
Well, I have confirmed as of 3am local time, NG has NOT disabled the Autoupdate . . .
BUT this is a 2 year old Router, not new. We'll see what tfc3000 updates us with.
- jg62Jun 19, 2022Star
I down graded fw to .5 and sure enought this moring rtr upgraded to .7 and took my network down now for almost the 10 th time. I had to reboot the rtr and then go through set up process again and this also means reconnecting over 3 dozen smart devices in my home. Taking down security cameras and everything else in a smart home. Seeing a flood of LAND Attack SPT:2190 DPT:2190 messages gain in logs from my onw ISP again. This is rediculous. This brick is only 7 months old but netgear on provides 90 day warranty. I opened a hardware case by phone as site would not let me but kept trying to push extended warranty sale and then NG has nerve to ask for a customer service survey.
The kicker is that when I went to check status, they closed my case as repaired. This the support case# 46119752 they saw fit to just close. Don't if I should just invest in another companies gear as this is insane after having paid nearly $500 for a brick. We are going to need a class action against NG as clearly they are unresponsive.
- Fuzmaniac1Jun 19, 2022TutorIf you get your modem/router set up as desired, including the access control, save the settings (there is an option to do so). If you have to factory reset or the system factory resets the device, you can reload those settings. Unfortunately, this only helps recover from the problems noted and not in resolving them. I finally solved my problem by switching to another company’s devices and will never buy another Netgear product.
