Moreno279
Jun 11, 2022Aspirant
CAX80 keeps rebooting
For the past 3 days my CAX80 has been rebooting every 4 to 5 hours. I’ve tried connecting the power source directly to an outlet and that didn’t work. I did a factory reset and that also didn’t work. ...
brettdotcom14
Jun 19, 2022Aspirant
i believe you can add me to this list as well. my ISP is optimum. my cax80 resets multiple times a day. the only difference is when mine resets the time resets as well and has to resync, might be an ISP thing. i may try to downgrade to .5.
its just incredibly annoying, streaming whatever, online gaming, any kind of pause kills it. especially when you invest so much into something that is suppose to be top of the line.
Omnitron
Jun 19, 2022Guide
In the meantime, does anyone know if it's possible to use the CAX80 as a router only (if so, which ethernet port acts as "input"), and use an old Arris Surfboard as my modem? Or do we think the CAX80 firmware issue is on the router side and not the modem side?
- My_UsernameJun 19, 2022Apprentice
It is not possible to use the CAX80 as a router only. Additionally, the device will enter a continuous boot loop and become an expensive paperweight any time a valid signal is not present on the coax. It's a deliberate flaw by design.
