Moreno279
Jun 11, 2022Aspirant
CAX80 keeps rebooting
For the past 3 days my CAX80 has been rebooting every 4 to 5 hours. I’ve tried connecting the power source directly to an outlet and that didn’t work. I did a factory reset and that also didn’t work. ...
Omnitron
Jun 19, 2022Guide
In the meantime, does anyone know if it's possible to use the CAX80 as a router only (if so, which ethernet port acts as "input"), and use an old Arris Surfboard as my modem? Or do we think the CAX80 firmware issue is on the router side and not the modem side?
My_Username
Jun 19, 2022Apprentice
It is not possible to use the CAX80 as a router only. Additionally, the device will enter a continuous boot loop and become an expensive paperweight any time a valid signal is not present on the coax. It's a deliberate flaw by design.
