Moreno279
Jun 11, 2022Aspirant
CAX80 keeps rebooting
For the past 3 days my CAX80 has been rebooting every 4 to 5 hours. I’ve tried connecting the power source directly to an outlet and that didn’t work. I did a factory reset and that also didn’t work. ...
Jun 21, 2022Guru - Experienced User
I would be concerned about the CPU usage being that high. Wow.
Are you seeing this all the time on the modem?
tamanaco wrote:
I've been trying to reply to this thread since early this morning, but my posts with screenshots don't make it. Trying without the images.
-> @2-days up and counting...
-> I still do not see the "A Router Firmware Update is Available" banner
-> The [DoS attack] LAND Attack SPT:2190 DPT:2190 Log messages are back at intervals ranging from ~1 to ~10 minutes apart. The source IP Address "xx.xxx.xxx.xx" is my ISP assigned WAN IP Address which as someone previously mentioned, is very strange as it looks like a "Suicide" DoS Attack. My ISP is Spectrum.
tamanaco
Jun 21, 2022Apprentice
FURRYe38... No, my CPU utilization is normally not that high. That screenshot was probably taken when my two NASes were syncing the previous day data. This usually happens overnight after 1am, but because of the router reboots I had to recently rescheduled the sync to 7am.
