Zythryn
Sep 24, 2024Initiate
CAX80 LAN address keeps reverting to default 192.168.1.1
I've had this router configured and installed for over a year, with no issues, with a configured LAN address of 10.1.1.1. This morning, I discovered the LAN address had reverted to 192.168.1.1. Thi...
Sep 24, 2024Guru - Experienced User
Can't say that I have, however last time I had my CAX80 online, I used 192.168.0.1 for it's address and it's always held.
Zythryn
Thanks, I also tried Chrome.
Looks like a factory reset is in my future đ
- FURRYe38Sep 24, 2024Guru - Experienced User
I always use MS Edge to configure mine.
- aerolanceOct 08, 2024Aspirant
Did you happen to find a solution to this? I am facing the same issue where I am unable to keep the network settings as 10.0.0.1 instead of 192.168.1.1. When I change the default IP address it always reboots and reverts back to default while also, a least 90% of the time, throws itself into a password reset loop.
Definitely would be grateful if someone has an actual solution. I've tried on every browser, factory resetting etc...
- FURRYe38Oct 08, 2024Guru - Experienced User
So your trying to set 10.0.0.1 and it won't take?
Had a factory reset and setup from scratch been performed with a ethernet connected PC and nothing else connected to the Modem?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
What other devices are connected to the modem?
