Dar77
Jun 21, 2022Follower
CAX80 lights and connections
So been having an issue with this modem the last 3 days. Was on the phone with xfinity trying to resolve the issue on sun 19th. The modem went offline for some reason and I couldn't connect at all. Al...
Jun 21, 2022Guru - Experienced User
Did the LED switch in back get flipped by chance?
Can you log into the modems web page and get access?
There is LED settings on the web page as well.
What happens if you disconnect the ISP coax cable from the modem for 1 minute? The modem should reboot and front LEDs should be seen...
