KWE325
Dec 04, 2023Aspirant
CAX80 loses 2.4 wifi band
This has happened to me twice in the last month - the 2.4 GHz WiFi band shows up as available, the light on the modem is lit but it cannot connect to anything, nor can anything connect to it. The eth...
Dec 05, 2023Guru - Experienced User
What devices do you have all connected?
What channel configurations are currently set on the router?
Is Smart Connect enabled on the modem?
- KWE325Dec 06, 2023Aspirant
Firmware is v2.1.5.2
Connected devices include Roku TV, Amazon Echo, ring camera, MacBook Air laptop, Epson printer, iphones and a Galaxy tablet.
Channel for the 2.4 wireless is Auto (9).
SmartConnect is NOT enabled.
On any given day there is as many as 3 or 4 wifi neighbors.
- FURRYe38Dec 06, 2023Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz
Does the front LED on the modem for 2.4Ghz turn OFF when this happens?
First off, Thank you for all your help regarding this!
DEVICES:
Device Name IP Address 2.4G Wireless 50" Roku TV 2.4G Wireless Amazon Fire TV Cube 2.4G Wireless CuboAi Plus Smart Baby Monitor 2.4G Wireless Echo Show 2.4G Wireless Echo Show 8 2.4G Wireless Galaxy Tab A8 10.5" 2.4G Wireless Gaming controller 2.4G Wireless iPhone XR 2.4G Wireless Kasa Smart Light Bulb Dimmable 2.4G Wireless Lenovo Think Pad T-590 2.4G Wireless Macbook Air 2.4G Wireless Ring Stick Up Cam 2.4G Wireless Ring Video Doorbell 2.4G Wireless Wemo Smart Plug 5G Wireless Amazon Fire HD 10 5G Wireless iPad 6 5G Wireless Microsoft Surface 6 5G Wireless PlayStation 5G Wireless SmartPhone 5G Wireless TP-Link - AX3000 Dual-Band Wi-Fi 6 Range Extender Wired My Cloud Wired Roku Ultra I have set the channel to 11 on the 2.4 wireless as per your advice.
The 2.4 light remains on; to look at the modem/router, you would not know there was an issue.
The FW update was performed on initial set up last year. This is the second CAX80 I've had, the first one was returned under warranty.
I was under the impression that a factory reset was a last-ditch effort, if all else fails. Is that true?
