Too_eazy
Sep 01, 2021Follower
CAX80 losing internet connectivity several times per day.
I'm not sure what info is needed, but my firmware is up to date. All of my devices are still connected to the WiFi networks, but internet connectiivty is down several times per day. I launch my nig...
Sep 01, 2021Guru - Experienced User
A screen snip of the cable connections page (shows upstream/downstream values) and your event logs helps us to check the connection.
If you don't have a good connection, it doesn't matter if you go buy a different device.
