I am having the exact same issue with Cox in Arizona. Router loses the Internet connection 1-2X per day and I have to reboot to get it back. Cox came out and replaced my cable line just to be sure, said they are not seeing any timeouts or packet loss and the signal levels are all in range.
Is this the table you're referring to?
Cable Connection
Cancel Apply |
| Startup Procedure |
| Procedure | Status | Comment | | Acquire Downstream Channel | 783 MHz | Locked | | Connectivity State | OK | Operational | | Boot State | OK | Operational | | Security | Enabled | BPI+ |
| Downstream Bonded Channels |
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables | | 1 | Locked | 256 QAM | 1 | 783000000 Hz | 0.6 dBmV | 39.3 dB | 9372 | 14112 | | 2 | Locked | 256 QAM | 33 | 357000000 Hz | 3.2 dBmV | 40.5 dB | 17 | 0 | | 3 | Locked | 256 QAM | 2 | 789000000 Hz | 0.5 dBmV | 39.1 dB | 1518 | 2839 | | 4 | Locked | 256 QAM | 3 | 795000000 Hz | 0.2 dBmV | 39.0 dB | 57 | 0 | | 5 | Locked | 256 QAM | 4 | 801000000 Hz | 0.0 dBmV | 38.8 dB | 79 | 0 | | 6 | Locked | 256 QAM | 5 | 807000000 Hz | 0.0 dBmV | 38.8 dB | 91 | 0 | | 7 | Locked | 256 QAM | 6 | 813000000 Hz | 0.0 dBmV | 38.7 dB | 89 | 0 | | 8 | Locked | 256 QAM | 7 | 819000000 Hz | 0.2 dBmV | 38.8 dB | 94 | 0 | | 9 | Locked | 256 QAM | 8 | 825000000 Hz | 0.2 dBmV | 38.7 dB | 909 | 1767 | | 10 | Locked | 256 QAM | 9 | 831000000 Hz | 0.1 dBmV | 38.6 dB | 381 | 914 | | 11 | Locked | 256 QAM | 10 | 837000000 Hz | 0.0 dBmV | 38.4 dB | 738 | 1543 | | 12 | Locked | 256 QAM | 11 | 843000000 Hz | 0.2 dBmV | 38.4 dB | 82 | 0 | | 13 | Locked | 256 QAM | 12 | 849000000 Hz | 0.4 dBmV | 38.3 dB | 130 | 0 | | 14 | Locked | 256 QAM | 13 | 855000000 Hz | 0.4 dBmV | 38.3 dB | 122 | 0 | | 15 | Locked | 256 QAM | 14 | 861000000 Hz | 0.0 dBmV | 38.1 dB | 141 | 0 | | 16 | Locked | 256 QAM | 15 | 867000000 Hz | 0.0 dBmV | 38.1 dB | 158 | 0 | | 17 | Locked | 256 QAM | 16 | 873000000 Hz | 0.1 dBmV | 38.2 dB | 136 | 0 | | 18 | Locked | 256 QAM | 34 | 363000000 Hz | 3.1 dBmV | 40.7 dB | 22 | 0 | | 19 | Locked | 256 QAM | 35 | 369000000 Hz | 2.7 dBmV | 40.7 dB | 52 | 0 | | 20 | Locked | 256 QAM | 36 | 375000000 Hz | 2.6 dBmV | 40.6 dB | 18 | 0 | | 21 | Locked | 256 QAM | 37 | 381000000 Hz | 2.7 dBmV | 40.7 dB | 23 | 0 | | 22 | Locked | 256 QAM | 38 | 387000000 Hz | 2.7 dBmV | 40.7 dB | 58 | 0 | | 23 | Locked | 256 QAM | 39 | 393000000 Hz | 2.6 dBmV | 40.7 dB | 644 | 276 | | 24 | Locked | 256 QAM | 40 | 399000000 Hz | 2.2 dBmV | 40.6 dB | 13 | 0 | | 25 | Locked | 256 QAM | 41 | 405000000 Hz | 2.1 dBmV | 40.6 dB | 12 | 0 | | 26 | Locked | 256 QAM | 42 | 411000000 Hz | 2.1 dBmV | 40.5 dB | 73 | 0 | | 27 | Locked | 256 QAM | 43 | 417000000 Hz | 2.2 dBmV | 40.6 dB | 53 | 0 | | 28 | Locked | 256 QAM | 44 | 423000000 Hz | 2.3 dBmV | 40.6 dB | 41 | 0 | | 29 | Locked | 256 QAM | 45 | 429000000 Hz | 2.1 dBmV | 40.5 dB | 73 | 0 | | 30 | Locked | 256 QAM | 46 | 435000000 Hz | 2.0 dBmV | 40.5 dB | 56 | 0 | | 31 | Locked | 256 QAM | 47 | 441000000 Hz | 2.0 dBmV | 40.6 dB | 173 | 0 | | 32 | Locked | 256 QAM | 48 | 447000000 Hz | 1.9 dBmV | 40.6 dB | 173 | 0 |
| Upstream Bonded Channels |
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power | | 1 | Locked | ATDMA | 6 | 2560 Ksym/sec | 12900000 Hz | 30.5 dBmV | | 2 | Locked | ATDMA | 1 | 5120 Ksym/sec | 17700000 Hz | 27.8 dBmV | | 3 | Locked | ATDMA | 2 | 5120 Ksym/sec | 24100000 Hz | 29.3 dBmV | | 4 | Locked | ATDMA | 3 | 5120 Ksym/sec | 30500000 Hz | 30.0 dBmV | | 5 | Locked | ATDMA | 4 | 5120 Ksym/sec | 36900000 Hz | 31.0 dBmV | | 6 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV | | 7 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV | | 8 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
| Downstream OFDM Channels |
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords | | 1 | Locked | 0 ,1 ,2 ,3 | 159 | 300000000 Hz | 7.48 dBmV | 43.0 dB | 1108 ~ 2987 | 917553354 | 210270956 | 8 | | 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | 0 dB | 0 ~ 4095 | 0 | 0 | 0 |
| Upstream OFDMA Channels |
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | | 1 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | | 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV |
| Extended Upstream Transmit Power |
| Enable Extended Upstream Transmit Power |
| Current System Time:Fri Sep 18 12:55:27 2020 |
| System Up Time:05:21:15 |
