jdimailig
Aug 01, 2020Follower
CAX80: Modem is offline - Please check RF connection
Netgear Nighthawk AX8 (CAX80) ISP: Comcast (Xfinity) Hardware Version: 1.01 Firmware Version: V1.1.0.36 Cable Firmware Version: V1.02.08 Trying to get the new CAX80 up and running, replacing ...
vkdelta
Sep 19, 2020NETGEAR Employee Retired
jesmith602 Please post Event Logs + Logs as well (two different pages.
yes, this is the table.
jesmith602
Sep 19, 2020Apprentice
vkdelta Thank you, the log is attached. The event log was empty (is that normal?).
- vkdeltaSep 22, 2020NETGEAR Employee Retired
event log is generally never empty.
can you please post a screenshot?
- jesmith602Sep 22, 2020Apprentice
Here are all 3 logs including events. Thank you.
- jesmith602Sep 27, 2020Apprentice
Hi vkdelta plemans -- I'm now on my second CAX80, and still having frequent disconnects. Support instructed me to have Cox reprivision the MAC and perform a hard reset with these steps, but it didn't help. Any other suggestions?
- For 2.4ghz wireless network, change the channel from auto to 11.
- For 5ghz wireless network, change the channel from auto to 128.
- Uncheck the box " Enable AX band ".
- Enable "Beamforming", "MU-MIMO", "Airtime Fairness".
Thank you.
